Do I Need to Install All of My Old Versions of LabVIEW?
Updated Feb 15, 2018
I have multiple previous versions of LabVIEW, and I am not sure if i need to have all of them installed. I have several applications written in LabVIEW releases from 2012 to 2017 and I want to make sure they all still work.
LabVIEW releases are backwards compatible through several previous versions. A chart of version compatibility is available in this tutorial. Opening files from previous compatible versions in a newer release will automatically update the file to the newest version.
If you have built applications in a previous release, you will want to rebuild the application installer in the most recent release and include the proper Run-Time Engine.
