The TestStand Engine Cannot Be Initialized
Updated Jul 17, 2026
  • TestStand
I have tested my Test-Sequence-file on my development System and everything works fine.
After deploying the TestStand Sequence-file to another System where I only run it with runtime, the following error occurs:
The TestStand Engine cannot be initialized.
Access Denied.
This issue could be caused by missing Windows User-permissions. If an Operator has not the permissions to read&execute inside the folder where the Userinterface is located, this issue could occur. If this is the reason, then you can solve the issue by giving the Operator permissions to read&execute inside the directory where the folders and files of the deployment are placed.
Here I linked you how to change the folder and file permissions on a Windows 10 System.
In general you should check that the operator has the right Windows permissions where the files are located. Especially when you are creating reports there is a write permission needed inside the directory where the report will be placed.
Here you can find the deployment best practice.
