Does NI ADCS Support Extended Addressing?
Updated Feb 16, 2018
  • Automotive Diagnostic Command Set Toolkit
  • NI-XNET
  • NI-CAN
I want to diagnose ECUs that use extended CAN IDs (29 bits long). The software product page does not explicitly mention this compatibility.
NI ADCS does support extended CAN IDs. Create Extended CAN IDs VI implements the
construction of these 29-bit long CAN identifiers which you can then use directly in Open Diagnostic VI
For further reference consult page 5-16 of the CAN and LIN Automotive Diagnostic Command Set User Manual.
