Can I View the Source Code of my cRIO Startup Executable?
Updated Mar 6, 2018
  • cRIO-9004
I have a cRIO that was bought pre-programmed from a third party with a startup executable. Is there anyway to see the source code that the startup executable is running?
There is no way to view the block diagram and code of your Real Time Startup Executable, unless you already have access to the source code that the executable was built on.
If it was bought from a third party contact the developer.
