Instr.lib and DAQmx Functions Show File Path as Title of Help
Updated Jun 14, 2018
  • My context help shows the file path of a function, rather than the name of the function in context help.
  • I changed the location of the instr.lib folder to a network drive, and want to return it to default.
  1. Open LabVIEW, and go to Tools>>Options.  There should be a submenu labeled Paths.  Make sure Use default is checked, to ensure the VI Search Path is set to default locations.
  2. If this does not work, force reinstall LabVIEW.
