Error -50303 shows up when performing self-test on NI MAX
Updated Apr 19, 2023
  • NI-9228
After plugging the DAQ device, it shows up differently than other DAQ devices in NI MAX. When I perform a self-test, the error -50303 shows up.
Install the appropriate DAQmx Driver version.
Refer to Device Support on DAQmx Driver readme to make sure device is supported by DAQmx driver.
You should use the most recent version of the DAQmx Driver Version supported by your software and hardware.
