NI PXIe 1073 and PXIe 8100RT Compatibility
Updated May 3, 2018
  • PXIe-1073
  • PXIe-8100
My PXIe 8100RT card does not fit inside my PXIe 1073 chassis.
The PXIe 1073 has a built in controller, therefore it has a built in MXIe connection and can not accept a modular controller such as the 8100RT.
To use a real time operating system you will need a different chassis that accepts a controller in slot 1. You can find a compatible chassis using the PXI Advisor.
