How Do I Do High Precision Moves With the NI 9514?
Updated May 3, 2018
  • NI-9514
  • LabVIEW SoftMotion Module
The minimum angle of rotation with my drive is orders of magnitude larger than it should be. Using a Position Move in LabVIEW, if I move to a position equal to 1, and then a position equal to 2, the angle between those points is larger than it should be.
I also cannot make fractional steps. And if I change the Counts Per Unit in Encoder Properties, that just changes the number I have to put into LabVIEW, but doesn't actually help the precision of my step size.
Not getting the full precision of your drive is usually a problem with tuning. You need to check the PID tuning parameters. After adjusting those properly, you should see the angles of your movements changing.
