Missing Components When Building Measurement Studio Application
Updated Mar 6, 2018
  • Measurement Studio
  • NI-VISA
  • NI-488.2
I recently transferred a Measurement Studio application to another computer. When compiling the application, I get the following errors:
  • The referenced component 'NationalInstruments.DAQmx' could not be found.
  • The referenced component 'NationalInstruments.NI4882' could not be found.
  • The referenced component 'NationalInstruments.VISA' could not be found.
These error messages can be resolved by installing the correct hardware drivers. Install the appropriate driver using the links to the drivers below: Be sure to install the appropriate support depending on the programming language you're using, as seen in the image below:
