Hardware Reliability - Datasheet Terms Explained
Updated Feb 23, 2018
  • Multifunction I/O Device
  • CompactDAQ Chassis
  • CompactRIO Chassis
  • Analog Output Device
  • PXI Analog Input Module
  • Digital I/O Device
  • PXI Digital I/O Module
How do I calculate the reliability of my NI hardware? What do all the terms on NI's datasheets mean? For example, what do terms like:
  • Typical Specification
  • Characteristic
  • Absolute Accuracy
actually mean?
Example Scenario:
My NI 9264 Voltage output module has a typical current of ±4mA per channel at 5V. What does typical current mean? Am I able to draw ±5mA? And if so, will this affect the reliability of the module?
There are a lot of terms used on NI datasheets, and there are a lot of articles which explain them. Below is a list of the white papers which describe the terms in the most concise way:
In order to calculate the reliability, follow the link below:
Example Scenario Answer:
To find the correct information for the Example Scenario, look in the above links:
