Value of the Pull-Down Resistors On-Board the NI 9403 Module
Updated Mar 27, 2018
  • NI-9403
Which is the value of the resistance located on-board the NI 9403 C series module?
The 9403 module contains a 47 kΩ pull-down resistor for each channel.
  • The DIO channels have Schmitt trigger inputs and are compatible with 5 V/TTL logic devices.
  • Each input channel has hysteresis for improved performance with noisy and non-monotonic input signals.
