CompactRIO-904x and CompactRIO-905x Series:
NI-DAQmx is compatible with the cRIO-904x and cRIO-905x families of controllers. For an example of how to use DAQmx on these controllers, please see
Continuously Acquire Data Using CompactRIO with the NI-DAQmx API, as well as the Related Links section of this article. Find more information about these devices here:
What is CompactRIO with NI-DAQmx?
Other CompactRIO Controllers:
The NI-DAQmx driver is not compatible with other controllers on the CompactRIO platform (900x, 901x, 902x, 903x, 906x, 907x, 908x, among others). This is because these CompactRIO controllers do not contain the NI-DAQmx specific hardware. Even if you are using C Series modules that are compatible with the CompactDAQ (cDAQ) platform, you will have to use either the RIO Scan Interface Mode or the FPGA Interface Mode to program the modules on the CompactRIO.
