Which Is the Maximum Resolution for the PXIe-8880?
Updated Feb 15, 2019
  • PXIe-8880
Other
  • PXie-8880
  • I am trying to connect my PXIe-8880 embedded controller to my monitor and I would like to know which is the maximum resolution that I can achieve. For example we are trying to figure out if we can do a single 32” 4K monitor.
  • Can I expand the graphic resolution of my PXIe-8880 to support 4K monitors and above?
The solution for this issue is to obtain the specifications and possible resolutionas that can be acomplished using the PXIe-8880. Taking in consideration the specifications from the NI PXIe-8880 User Manual at page 12, the E6460 graphics card is the hardware that limits the specification of the maximum resolution.
From the AMD today regarding the maximum monitor resolution of the E6460 graphics card and under the DisplayPort 1.2 the resolution is 2560 x 1600.
