- I get error -200946 when using my USB DAQ device.
- The error is intermittent, or doesn't always happen within the same time frame.
- This message sometimes happens when my application has been running for a long time.
Error -200946 occurred at Untitled 1
Possible reason(s):
Task could not be started, because the driver could not write enough data to the device. This was due to system and/or bus-bandwidth limitations.
Reduce the number of programs your computer is executing concurrently. If possible, perform operations with heavy bus usage sequentially instead of in parallel. If you can't eliminate the problem, contact National Instruments support at ni.com/support.
