Do I Need to Calibrate My NI TB-4300B?
Updated Feb 20, 2018
  • TB-4300B
I am calibrating my PXIe-4300 and am wondering if I have to calibrate the TB-4300B terminal block that I'm using with the device as well. If I do, what is the procedure?
Yes, we recommend you calibrate the TB-4300B at least once every 5 years. The calibration procedure for the device can be found here.
