NI MAX Hangs After Installing DIAdem on Windows 10
Updated Feb 12, 2018
  • DIAdem
After I installed DIAdem on my Windows 10 computer, I am no longer able to open NI Measurement and Automation (NI MAX) and view my devices.  When I open up NI MAX, NI MAX just hangs there either loading plug-ins or searching for devices.  I am not able to close out of NI MAX even when I try to kill the process in Task Manager.  The only way I am able to get NI MAX to close after I open it is to restart/power cycle my computer.
The first version of DIAdem that officially supports Windows 10 is DIAdem 2015 SP1.  If you are using previous versions of DIAdem on a Windows 10 computer, you may see unexpected behavior such as NI MAX not functioning normally.
To resolve this behavior, you have two options:
