Error -201304 When Running DAQmx Voltage-Continuous Input Example
Updated Jun 29, 2018
I want to acquire from a data acquisition board and save directly into TDMS file.
When I run the LabVIEW example Voltage - Continuous Input .vi I receive error message:
Error -201304    File path specified is invalid, or the file is not a valid TDMS file. Specify the location of a valid TDMS file.
Why?
The problem is that you are selecting the same tdms file to be written.
In order to avoid the error, you have two options:
  • Change the file name before running the vi.
  • Go to the DAQmx Configure Logging (VI) and change the operation to Create or Replace
