One Counter On PXIe 6614 Doesn't Count Intermittently
Updated Jun 14, 2018
  • PXIe-6614
I am using a PXIe-6614 module to count about a 5 MHz pulse train that I am generating using a ticks counter output task. One counter intermittently does not count input pulses. The other 7 counters are working correctly with the same settings.
Try changing the pulse train generation to generate the pulses based on frequency instead of ticks to see if this results in a different behavior.
