DIAdem VIEW Loads 2D-Axis Data Slowly
Updated Jan 3, 2019
  • DIAdem
I am loading data into a 2D-Axis in DIAdem VIEW and have noticed 5-10 minute load times.  What could be causing this?
There are a few steps to try to speed up load times:
  1. Change the Data Loading behavior to "Always load bulk data".  This will increase processor load some but decrease load times:
  2. Disable any startup scripts that might be running.  From the DIAdem environment, select Settings >> DIAdem Settings >> General.  There should be a Start Script field.  Make sure this is not populated.
  3. Rename Desktop.DDD to remove any references to VIEW events you may have configured.
  4. If you are loading a preconfigured .TDV file on startup, load an empty .TDV and manually load your custom .TDV file after importing data.
