NI FRC RoboRio CAN Port Is Not Communicating With Talons SRX
Updated Jun 25, 2018
  • roboRIO
On the Web Interface, the RoboRio for FIRST Robotics Competition (FRC) does not see the TALONS FRX device as communicating with the RoboRio.
  1. Check Wiring and that connections are tight
  2. Check if the if the CAN port shows in the Web interface with the PDP plugged into the CAN port
  3. If not, reload the Firmware
  4. Install the Pheonix Update
