Connect All Inputs and Outputs on My Switch Module
Updated May 3, 2018
  • PXIe-2527
  • PXI-2501
  • PXIe-2569
I need to simultaneously connect multiple outputs to a single input programatically. Can I do this on a PXI switch module by closing all the switches to have all the inputs and outputs connected?
This is possible on a switch module if the switch supports matrix topology. The product page or datasheet will mention that the card can be used as a matrix switch if it supports this, such as the PXI-2501. If your card only says it can be used in multiplexer mode, such as the PXIe-2527, then the driver will not allow you to close more than one switch.
If the switch card is a mux, the software will not allow you to do this. If it is a matrix used in a mux topology, this works. Trying to do so on a mux card will give the following error: "Route cannot be found between the specified endpoints."
Even if your card does support matrix switching, this is not the typical use case of a switch. If your goal is to connect a single input to multiple outputs, a relay module such as the PXI-2569 would be more appropriate.
