25 Pin Micro D-Sub to Standard GPIB Cable for PXI Controllers
Updated May 3, 2018
  • PMC-GPIB
  • PXI Controller
  • Controller for VXI
I purchased a VXI controller, PXI(e) controller, or PMC-GPIB module, and the I/O connector for GPIB is listed as a Micro D-Sub 25-pin connector, not the standard IEEE 488 24-pin connector. Does this mean that I need a special cable?
Yes, these products are too small for the full size GPIB connector and therefore use a non-standard GPIB cable.  You can purchase these cables as an accessory for any device which has the 25 pin Micro D-Sub GPIB connector.  They will be an option under accessories on the purchase page of the product.
The cable is an X13 GPIB cable.  If you need to order a replacement, the part numbers are:
183285-01 (1m)
183285-02 (2m)
183285-0R2 (.2m)
