Modular Data Acquisition
High-Performance Test
The file does not contain a valid file format.
What do I need to do to be able to launch VeriStand without this error?
This error occurs because Data Environment Settings.xml has become unreadable; either the file is corrupt or blank. To resolve the error, follow these steps:
Note: ProgramData could be hidden. If you can't see the folder, modify the folder view option.
