My DAQmx Installation is Missing the Library "nidaqmx.h"
Updated Apr 9, 2025
  • LabWindows/CVI
Programming Language
  • Python
  • C
I am trying to use an object-oriented programming language to program NI hardware using the DAQmx library. The header file is included in my program, and when running I get the following error message.
​ 'NIDAQmx.h': No such file or directory
What can I do to solve this issue?
The header file NIDAQmx.h should be located in the following folder:
Program Files (x86)\National Instruments\NI-DAQ\DAQmx ANSI C Dev\include\NIDAQmx.h
If it is missing, try these steps:
