Measure Resistance of a Load in a Resistor Network with a PXIe-4081
Updated Jul 17, 2018
  • PXIe-4081
  • PXI-4022
  • PXIe-4080
I want to measure the resistance of a resistor that's in parallel with other resistors using a PXIe-4081 DMM.  How can I minimize current leakage when making the measurement?
You should use the PXI-4022 in conjunction with the PXIe-4081 to guard against parallel resistances or contamination.  The Improve Resistance Measurement Accuracy with 6-Wire Technique White Paper as well as the PXI-4022 Specifications provide details on how to connect the PXI-4022 and NI DMM to the DUT in order to configure the 6-wire measurement.
