When you are using a C Series Module in a Real-Time cDAQ chassis, you do not need to add the modules to the LabVIEW project like you do when using a cRIO. The I/O channels are accessible directly using the NI-DAQmx driver. To access the I/O channels, you can use a DAQmx Physical Channel control or constant in your VI, which will show any
DAQmx-compatible C Series Modules that are inserted into your chassis.
You can then
program your DAQmx code as you would if the VI were running on a Windows machine.
