CANopen Custom Baud Rate
Updated May 3, 2018
  • NI-9881
  • NI-Industrial Communications for CANopen
Can I set a custom baud rate with the NI-Industrial Communications for CANopen?
The NI-Industrial Communications for CANopen has 8 standard baud rate options, but you cannot set a custom baud rate. To set a custom baud rate for the CANopen protocol, consider using the CANopen Reference Example for the NI-9853 C-Series CAN Module
