Cabling Options for PXI-2576
Updated Apr 25, 2018
  • PXI-2576
  • TB-2676
  • TB-2676 Cable Kit
  • TBX-50
I have a PXI-2576 multiplexer switch module and want to know about what external cabling options are available.
For this particular module we have two options:
  1. Front-Mounted Terminal Block (TB-2676) with a Ribbon Cable Kit
  2. The LFH160 to 50-Pin D-Sub cable paired with the TBX-50 terminal block
For more information on recommended cables and accessories for NI Multiplexers see the Multiplexer Switch Modules Cable and Accessory Compatibility Guide
