Traditional NI-DAQ (Legacy) Windows Vista, 7, 8 and 10 Support
Updated Jul 9, 2019
  • Multifunction I/O Device
  • Traditional NI-DAQ
I want to install Traditional NI-DAQ (Legacy) Driver on Windows Vista, Windows 7, Windows 8 or Windows 10.
  • Is Traditional NI-DAQ (Legacy) supported on these 64-bit (x64) Windows versions?
  • Why does my LabVIEW VI, executable or application not run or is broken on these Windows versions?
  • Why do I receive errors when I try to run my LabVIEW executable on a Windows 10 computer?
  • Why do I run into problems or errors when installing Traditional NI-DAQ (Legacy) on these Windows versions?
  • Why is my DAQ device or module not showing up in Device Manager or Measurement & Automation Explorer (MAX) in these Windows Versions?
Traditional NI-DAQ (Legacy) vs NI-DAQmx
NI provides the Traditional NI-DAQ (Legacy) driver to support developers with legacy code needing to run on 32-bit versions of Windows Vista, Windows 7, and Windows 8.​  NI-DAQmx replaced Traditional NI-DAQ (Legacy) in 2003. NI strongly recommends using NI-DAQmx for new designs and migrating existing Traditional NI-DAQ (Legacy) applications to NI-DAQmx. Please review the Getting Started with NI-DAQmx guide for more information on migration.
Traditional NI-DAQ (Legacy) Windows 64-bit Support
64-bit versions of Windows are not supported.  These versions of Windows are only supported by the newer NI-DAQmx driver.
Traditional NI-DAQ (Legacy) Windows 32-bit Support
Use this article to determine the version of Traditional NI-DAQ installed on your system.
Traditional NI-DAQ (Legacy) Windows Version Support
Traditional NI-DAQ (Legacy) VersionWindows VistaWindows 7Windows 8Windows 10
<7.4.4UnsupportedUnsupportedUnsupportedUnsupported
7.4.4Unofficial*UnsupportedUnsupportedUnsupported
7.5SupportedSupportedSupportedUnofficial*
Note: All Windows version support noted is 32-bit only.
* This installation may work, but it is not supported by National Instruments.
Troubleshooting Traditional NI-DAQ (Legacy) Installations
