How To Run A Closed Source Library compiled For Linux RT Within LabVIEW RT
Updated Feb 7, 2018
  • LabVIEW Real-Time Module
  • NI Linux Real-Time
  • Linux
Programming Language
  • C
I need to run a library compiled for Linux RT within LabVIEW RT. The library is closed source so I cannot recompile it. How can I run this library in LabVIEW?
There is a way to redirect the system calls without recompiling. Provided your processors match, step 6 and onwards in the Integrating C Code with LabVIEW on NI Linux Real-Time Targets tutorial will explain the steps you need to take.
