DAQmx Reads the Same Data Repeatedly
Updated May 3, 2018
  • Multifunction I/O Device
I want my DAQ device to output data once and then stop. The same data keeps being output over and over continuously. How can I output the data only once?
Make sure that your DAQmx Timing (VI) is set up sample a finite amount of points. If you set it to continuous, it will keep outputting the data until the program stops.
