Can't Find FRC RoboRIO Project Template In LabVIEW
Updated Mar 6, 2018
  • roboRIO-FRC
When I open LabVIEW 2017 and go to try to create a new RoboRIO Project from template, I can't find the getting started template. Why?
  • When you have LabVIEW 2017 and the FIRST 2018 Update Suite installed, the example RoboRIO project will appear on the LabVIEW getting started window under new as "FRC RoboRIO Project".
  • If you do not see the project template, make sure you see a black banner on your LabVIEW getting started window that says "FRC 2018 Beta". If you do not see this, make sure you have the correct environment selected by going to Tools > Choose Environment > LabVIEW for FRC"
  • If this environment overlay does not appear, ensure you have the FRC 2018 Beta Software installed which can be located on our download page.
