Error Loading Assembly with Constructor Node
Updated Nov 7, 2019
When I open the constructor node in my VI and browse for the correct assembly( from a previous .NET framework) I receive an error in the objects section. The error appears and prevents me from clicking "OK" on the dialog box.
 You should use the following link to create the configuration file for .NET 2.0, 3.0, and 3.5 Assemblies   to target older versions of the CLR.
CLR stands for Common Language Runtime and has certain requirements in order to create or manipulate .NET objects in LabVIEW.
If using an older version of LabVIEW use the following link to create the configuration file for the .NET 4.0 Assemblies .
