When I open the constructor node in my VI and browse for the correct assembly( from a previous .NET framework) I receive an error in the objects section. The error appears and prevents me from clicking "OK" on the dialog box.
You should use the following link to create the configuration file for .NET 2.0, 3.0, and 3.5 Assemblies to target older versions of the CLR.
