Reference VeriStand Custom Device Channel for .NET Constructed Alarm
Updated Jan 4, 2019
  • VeriStand
Programming Language
  • C# .NET
  • Visual Basic .NET
I'm trying to create an alarm in LabVIEW for a VeriStand system definition referencing a custom device channel. However, I can't seem to reference the channel correctly since I always get error 1057 when running the VI.
I can't seem to cast the channel to the right type. How do I fix this?
You can work around this by obtaining the custom device channel type, then using this to construct a new channel as a channel reference for your alarm. Below is a screenshot illustrating how to construct the new channel from the custom device section of the system definition file you are referencing.
