Requirements for Converting Vision Builder Script to LabVIEW VI
Updated Feb 26, 2018
  • Vision Development Module
I am trying to convert my VBAI to a VI. When inside of the Vision Builder AI application, I click on Tools > Migrate to LabVIEW.  I then receive a popup message that says I am missing Vision Development Module. Does this not come with the Vision Builder Installation?
In order to convert Vision Builder Script to LabVIEW code you will need Vision Development Module.  Also, to run the code once you convert it you will need either Vision Development Module installed or a Vision Run Time License.  You won't be able to use the code without purchasing VDM.
