Is LabVIEW Supported on Linux Ubuntu
Updated Jun 30, 2020
  • Linux
Does LabVIEW work on Linux Ubuntu operating systems?
Currently Ubuntu is not an officially supported operating system for LabVIEW.
Check LabVIEW and Linux OS Compatibility to determine which versions of Linux distribution and LabVIEW are compatible. Additionally, you can check the readme for your software which can be found in LabVIEW Downloads.
If you are interested in using NI Software with your Linux distribution, check the Download page for your software to determine if a download is available for Linux. If so, check the readme for your software version to determine which distributions are compatible.
