Can't Add NI-9262 to My LabVIEW Project
Updated May 3, 2018
  • NI-9262
  • CompactRIO Chassis
  • LabVIEW 2017 Full
  • LabVIEW 2017 Professional
I am trying to add the NI-9262 module to my LabVIEW Project, but the auto discovery is not finding it, and it doesn't appear on the drop down menu to manually add it.
Support for the NI-9262 was added in the NI CompactRIO Module Support 17.1.0 update. You will need to download and install the update to use the NI-9262 with LabVIEW 2017. After installing the update to your computer, you will need to install it onto your CompactRIO (cRIO) as well. Also, the NI-9262 is an FPGA module, so it needs to be added under the FPGA target of your cRIO.
