Rename Physical Channel in the TDMS file When Using the Function DAQmxConfigureLogging
Updated Feb 20, 2018
  • LabWindows/CVI
I'm using the function DAQmxConfigureLogging to log automatically into TDMS file.
How to rename the physical channel in the TDMS file programmatically?
In order to write a different name instead of the physical channel in the TDMS file, you need to change the Name_To_Assign_To_Channel parameter on the DAQmxCreateAIVoltageChan function, or any other DAQmxCreateAI function.
Example:
DAQmxCreateAIVoltageChan(taskHandle,"cDAQ1Mod1/ai0","VoltageCH0",DAQmx_Val_Cfg_Default,min,max,DAQmx_Val_Volts,NULL);
DAQmxCreateAIThrmcplChan (taskHandle, "cDAQ1Mod1/ai1", "TEMPCH1", 0.0, 100.0, DAQmx_Val_DegC, DAQmx_Val_J_Type_TC, DAQmx_Val_ConstVal, 25.0, "");
In the TDMS file, you will see the "VoltageCH0" and "TEMPCH1" instead of the physical channel.
