Axis Camera Will Not Work With LabVIEW for FRC
Updated Jan 4, 2019
Other
Axis Camera for FRC
I'm working on connecting to an Axis camera for FIRST Robotics Competition (FRC) and it doesn't seem to be working.
Check that you have set the Boolean constant in "Vision Processing.vi" to false in order to select the Axis camera instead of the USB. The Boolean constant default value of true can be seen in the screenshot below.
