Error 65536 In LabVIEW Real-Time
Updated May 5, 2025
  • CompactRIO Chassis
  • LabVIEW Real-Time Module
Why do I see the following error when I try to run an example real-time VI or my own real-time code?
Error 65536 occurred at an unidentified location
Possible reason(s):
CompactRIO (Hex 0x10000) Unable to communicate with the module. Reinsert the module and check connections.
Check for the following possible solutions:
C-Series module and cRIO mode incompatibility
  • Reinsert the module and check connections.
  • If the chassis is in FPGA Interface programming mode, make sure you have opened an FPGA reference to a bitfile or FPGA VI with Scan Interface support for the module you are trying to access using the Scan Interface. (If you get same error after this, you can also check that the DMA FIFO's are being initialized before the Shared Variables)
  • If the module you are trying to use requires Scan Interface mode but your compactRIO target is in FPGA mode, refer to: How Can I Use Scan Engine and FPGA Simultaneously on a CompactRIO (Hybrid Mode)?
C-Series module and Slot configuration incompatibility
  • This error message can appear when a slot in a CompactRIO (cRIO) chassis is configured for a module other than the module currently inserted in the slot. This usually happens when a module that takes a long time to power on is inserted in a slot configured for a fast module.
    • Add a delay of a couple of seconds to the start of the FPGA VI to give the I/O node enough time to detect the module properly. If after doing this you receive an incorrect module error/warning, either reinsert the modules in the correct locations or appropriately change the I/O module setup in the FPGA Project.
