Can I Use Python to Program a CompactRIO?
Updated Sep 16, 2019
  • CompactRIO Chassis
  • CompactRIO Controller
  • LabVIEW FPGA Module
Programming Language
  • Python
I would like to use Python to program a CompactRIO (cRIO). Can I do so?
You can program the CompactRIO with the NI FPGA Interface for Python. Please note that to do so, you will have to have a compiled bitfile for your specific cRIO target (compiling a bitfile for NI Hardware requires the LabVIEW and the LabVIEW FPGA module). This API does not directly program the cRIO's FPGA, but offers a way to access the FPGA target's I/O and other data.
Note: Real-Time Methods are not currently supported by the NI-DAQmx Python API.
You can also use the C/C++ Development Tools to program your cRIO as an alternative to Python.
