In 2020, NI released the LabVIEW FPGA IP Export Utility, which allows users to export FPGA code from LabVIEW to VDHL code. You can then use this VHDL code on any Xilinx Vivado™ FPGA device of the same family. See the LabVIEW 2020 FPGA IP Export Utility Readme for more information about compatibility and System Requirements.
The LabVIEW FPGA Module is designed to help you develop FPGA applications for NI reconfigurable I/O (RIO) hardware targets. These include:
For a comprehensive list of software and hardware combinations, please follow the links below:
Vivado is a registered trademark of Advanced Micro Devices, Inc.
