Are the COM Ports on my NI 9361 Connected Internally?
Updated May 3, 2018
  • NI-9361
I am working with an NI 9361 that has common connections on it. Is everything that I connect to a COM pin tied together / connected internally?
As per the NI 9361 Datasheet, the COM pins for each channel are all connected. Since there is no channel-to-channel isolation, but rather channel-to-ground isolation, you can wire to COM as appropriate using the Getting Started Guide under the assumption that these all refer to the module common ground.
NI 9361 Input Circuitry
