Changes in LabVIEW Code Needed When Upgrading Windows Operating System
Updated May 3, 2018
I have a working system running on Windows XP SP3. I want to upgrade my computer to Windows 10. What changes do I need to make?
The most important consideration to make when upgrading operating systems is the compatibility of your LabVIEW version. Reference this article to see if the current version of LabVIEW you are using is compatible with the operating system you are upgrading to. If the LabVIEW version you are using is compatible across both operating systems, no changes should be required in code.
If you do need to upgrade LabVIEW to a version that is compatible with the new operating system, reference this article for additional considerations that must be made.
