.\IdFile.cpp(123): InstallerError 11006 Xilinx Error
Updated May 3, 2018
  • FPGA Xilinx Compilation Tools
I'm trying to install the Xilinx Compiler. However, when I attempt to do so, I see these errors:
".\IdFile.cpp(123): InstallerError 11006" when I double click on setup.exe file.
" ...\autorun.exe is not a valid Win32 application" when I try to run autorun
Sometimes there is a corruption with the download and re-downloading will resolve the error.
In some systems, you need to select "Extract Here" to extract contents of the .iso file to the same folder where the original .iso file is. Then the autorun.exe should work as expected.
