SCXI Chassis Has Red X in NI MAX
Updated Jun 21, 2019
  • Chassis for SCXI
In NI MAX, my SCXI chassis appears with a red X next to it and I cannot communicate with it.
First ensure that you have a DAQmx version installed that is compatible with your SCXI chassis.
Then, follow these steps to reconfigure your SCXI chassis:
  1. Reset the MAX database. (Note: If there is any configuration data you would like to save, you will need to export it before resetting and then import it after Step 2).
  2. Connect the SCXI chassis to your computer or controller.
