Using NI-DAQmx TSN Features in C, C++, or .NET Environments
Updated Apr 25, 2019
  • cDAQ-9185
  • cDAQ-9189
  • NI-DAQmx 17.1
Programming Language
  • C# .NET
  • C
  • C++
  • I would like to use the Time Sensitive Networking (TSN) features of my cDAQ chassis to synchronize measurements or to use time triggers. How do I accomplish this using the C or .NET APIs for NI-DAQmx?
  • What resources are available to use TSN in C?
Performing Synchronized Measurements of the Same Type
The NI-DAQmx driver will automatically synchronize measurements between multiple TSN enabled cDAQ chassis by using channel expansion. When creating the multidevice task, you simply need to specify the channels located on the different chassis.
For a LabVIEW example of this synchronization, see Figure 3 in How to Achieve High-Accuracy Measurements With NI-DAQmx-Based TSN Devices.
Performing Synchronized Measurements of a Different Type
When performing measurements that are of different types (such as an Analog Input and Counter Input), you must have separate tasks in order to perform the measurements, and so cannot use channel expansion as above.
In this case, you can use the TSN features of the cDAQ chassis to start both tasks at the same time by using an absolute time trigger. See Figure 4 in How to Achieve High-Accuracy Measurements With NI-DAQmx-Based TSN Devices for a LabVIEW equivalent of this measurement configuration. Use the following for equivalent functions in the C/.NET APIs:
