You will need to either have the Vision Run-time Engine installed and activated or the Vision Development Module installed and activated on the deployment system. If you happen to have both the Vision Development Module and the Vision Run-time Engine installed, the Vision Development Module must be activated. The following table summarizes this information.
Installed Software
Required License
| Vision Development Module |
Vision Development Module or Vision Debug License*
| Vision Run-time Engine |
Vision Run-time Engine or Vision Development Module
Vision Development Module AND Vision Run-time Engine | Vision Development Module or Vision Debug License* |
*The Vision Development Module Debug License is intended for identifying problems, stepping through, and correcting vision applications. You cannot use the Vision Assistant with the Vision Debug License. The Vision Development Module must be installed a machine in order to use the Vision Debug License.
