Archived:Where Are the LabVIEW CANopen Library Examples Located?
Updated Feb 8, 2018
National Instruments does not actively maintain this document.
  • LabVIEW CANopen Library Toolkit
  • NI-CAN
  • NI-XNET
Programming Language
  • LabVIEW G
I have installed the CANopen LabVIEW Library. Now where can I find the CANopen Examples?
CANopen LabVIEW Library is not recommend for new designs.  NI recommends NI-Industrial Communications for CANopen and the NI 9881, NI PCI/PXI 8531.
The CANopen LabVIEW Library examples install to your LabVIEW examples directory, accessible through the NI Example Finder. You can access the NI Example Finder within LabVIEW by navigating to Help»Find Examples. With the NI Example Finder opened, you want to then select Directory Structure as illustrated in the following image.
